It is easy to differentiate between a JS3 and JP3. As only the JS3 will have oil feed lubrication to the rocker shafts, also the JS3 will not have compression changeover valves.
The JS3 engine is a high speed version of the JP3 engine, and is supposed to run at 1500 RPM, compared to the JP at 1200 RPM. This increase in speed was what caused crankshaft problems you are eluding to.
If you do have a JS3 engine, that will be a rare engine, as very few were made compared to JP engine.
