Author Topic: 10mm Bosch Mico Diesel Injector Pump Element  (Read 5100 times)
EdDee
« on: May 27, 2016, 03:29:28 PM »
Hi Guys,
Anybody round here who can point me in the right direction to get a couple of 10mm Bosch Mico pump elements for a 12/1 Roid?
Just about everybody I have tried so far on the local scene (ZA) have come up blank...
Ed
Re: 10mm Bosch Mico Diesel Injector Pump Element
« Reply #1 on: May 27, 2016, 04:26:31 PM »
I am not sitting where I have access to my pump specs and memory is not to be trusted :-\. My first call would be to Diesel Elecric Service and if that did not produce the part then IF 10MM is the standard issue element for that engine it is likely that Central Main Diesel will have it in stock in MICO .  My last resort supplier, only due to cost is Peter Slater Injection Engineers in England, they have yet to let me down, only problem is currency exchange plus shipping makes the parts VERY expensive.  I had a couple 10MM elements that came from one of those 3 suppliers. Should still be one ,,,,, somewhere.
Butch
listard-jp2
« Reply #2 on: May 27, 2016, 05:05:17 PM »
Why not cut out the middleman, and go straight to the source of supply for this part (after all it is not as if these components are going to cost a significant amount in postal costs):
http://www.ksdiesels.com/pro_elements5.htm
For a 10mm size element, I believe that will need part number: ET 10L 1/4 (be sure to specify the correct helix rotation, LH in your case)
EdDee
« Reply #3 on: May 30, 2016, 10:17:39 AM »
Hi L-jp2,
Thanks for the heads-up.... I have buzzed of an email to them to see whether they will post to ZA...
Many thanks
Ed
