Author Topic: lister sr3  (Read 5918 times)
occles
lister sr3
« on: April 28, 2016, 02:30:13 PM »
HI, I HAVE A LISTER SR3 with a brush 10kva generator i was told it used to be a startomatic but all i have is the generator the engine starts by turning the generator ie there is no starter how many batteries will i need to start it thanks in advance
Re: lister sr3
« Reply #1 on: April 28, 2016, 11:05:41 PM »
There are a number of Start-O-Matic models using differing voltages... mostly 24vdc starting (2 batteries in series) as far as I have seen though.
The SR might also offer you an option of using a conventional DC starter as well (available in 12 and 24 volts). Take a look at your flywheel and determine if the starter ring gear is installed or not. With ring gear in place, then the starter options are a bolt-on affair.
