Hi Guys,
We're using the CGG AVR on my neighbor's ST-3 with propane converted DES 8/1. It is using the Harmonic winding as the excitation source, since it just doesn't work at all using one leg of the line voltage (can't start even a 1/2 hp motor). Tom lists that configuration, but frankly, he should not.
On the harmonic the CGG AVR works fine on induction motor loads, but on non-linear loads like a small wire feed welder, or a Vitamix on (electronic controlled) low speed, it regulates the voltage so low our RMS voltage monitor trips. (regulates to 170V RMS instead of 240, and 85V on the stepped down 120V supply). On straight harmonic the ST-3 does fine on these same loads.
So alas, while Tom's price is appealing, the AVR being sold by CGG has some serious limitations:
1. You can use it only with the harmonic winding for excitation.
2. It regulates only to peak AC voltage levels, not RMS, and will down regulate to grossly low voltage for some non-linear loads.
Can anyone suggest a 240V AVR that does a decent job of regulation? Something that says "RMS" voltage in the specs perhaps?
