No, I've not installed a catalytic converter on my Listeroid. However, I am again considering the possibility.
VW jokes aside, smelling diesel exhaust all day while working in the yard, running off grid is simply nasty. My engine simply has mufflers attached to the exhaust ports. They stick out horizontally. This leads to exhaust fumes hovering at ground level and accumulating on my property. It also leads me to believe that the exhaust fumes are truly nasty. I hate diesel exhaust smell.
I'm considering mounting a set of high flow catalytic converters (one per cylinder) close to the head, in an attempt at reducing the pollution. My home typically does not draw all that much current, so the engine has long period of modest load. Even so, I believe there is enough heat to light off the cats.
Any thoughts? Any suggestions as to which one to purchase? Possibly VW will have a slew of less than effective exhaust treatment devices in the dumpster soon?
