Hey Tom/Hugh,
Tom, after the first stuff up with the watery dino, I now bring pretty much all fuel to the boil before I use it, but then again, I am a cheapskate and am using reclaimed oils only... since the first IP problem that is...
Hugh, I took a good look into the crankcase in both of my engines, and after much thinking and scratching my head, I can't see any real benefit to running the dipper in any other orientation other than crossways.... the more splashing around, the better I would think... if you start spewing oil from seals etc, crank vacuum is dodgy and needs attention... either in the rings department or in the vent department... but I cannot honestly see any benefit to less splash lube... if there is a valid reason to limit or lessen it, I certainly cannot see it...
The only reason I can see for shortening the dipper would be to allow a greater oil clearance below it in the sump/weir area to allow for more metal particles to slip into the apron, but, I don't think that a difference in dipper length would influence this greatly, maybe I am wrong though... anybody who has a better idea is welcome to correct me....
As far as I am concerned, when rings are bedded in, I am almost certain that you would need way more oil on the cylinder walls than what the max is that the dipper can put, to cause a problem... but maybe I am wrong.... What I can say though, TM1 is splashing oil around like a kiddy in a paddling pool, so far so good... There is certainly a logic to the angled dipper, throwing oil onto/into a less lubricated area, but with the dipper X ways, there is more than enough oil drenching everything... I just cannot wrap my head around the knife edge approach......
TM1 has a very bad seal between jacket and deck, even with the amount of oil being thrashed around, at full load, with the maximum gas being vented from the cc breather, there is less than a few droplets after a few hours running....
I have seen some long explanations regarding the dippers, but logic still tells me that the more oil flushing around, the better..
Your thoughts?
Regds
Ed
PS.... keep it spinning!
