Hey Tom, Bill and Glort,
I have a vac pump or 3 plus etc but don't want to use them for this app... My main interest was to see if I could still or crack the oil on a "micro" basis using the simplest means possible... Exhaust gas is exiting at about 350 to 500C depending on load, but the setup I am trying out just doesn't have the balls to collect and scavenge quite enough of the available temp to boil the oil. I can go to a more elaborate exchanger, but the problems with cleaning fins etc become an issue that I don't want to get involved in.
It was worth a try, if for nothing else, an indicator of what is required should I decide to take it further...
Glort, I agree pretty much entirely with your summation and opinions, but I also do think that the exhaust gas heat scavenging could be useful on a micro basis for oil cracking.... It would be nice to throw gunk into the monster and know that the gunk is being turned into champagne while it runs... To clean out a small crock of crap after every run or three is a lot better than tearing down to do rings etc because of the wear... I would only be looking to still off about 2 to 3L per hour, at most about 5... This will take care of the running with a little extra for reserve... Viewed in that light, it might change your opinion of the process I am investigating...
For me, a WMO/WVO burner would be overkill presently, even a really small one... the only reason I would look at a burner now, would be to use on my oil cooking machine which is electrically operated and heated... I am, however, currently doing trials on fuel that is not de-watered and boiled pre storage... so far it looks reasonable, the only process I am using is cold filtering with a sock filter on one pass, with 24hr minimum settling pre usage.....This is a much lazier and less messy way for me, should the lifespan of the IP element etc match previous or come close to it, I would tend to stick to it... Time will tell though, I am keeping full records to make a comparison.... Of interest though, when diesel WMO or Petrol WMO is hot dewatered, they burn very similarly as fuel... When cold processed, ie filtered, settled and used, there seems to be a marked difference in performance between the two as a fuel from a carbon as well as a power POV...
Regarding fuel preheating - If it was arctic conditions, I think it would make a difference, but here where I am, the difference is minimal and probably more psychological than actual...
Glort, I like your burners, particularly the simplicity and ease of construction....one of the things I noticed on a few of your vids was the amount of back flame you were getting on the open tubes close to the burner nozzle and the "buzz bomb" rattle as it lights off... Have you tried a conical inlet to the burner tube? Kind of like the cup on a rocket engine... Just thinking out loud....
Cheerz
Ed
