Author Topic: 7.5 st update  (Read 3226 times)
32 coupe
  • "Doc Johnson" on call !
7.5 st update
« on: September 21, 2015, 10:07:46 PM »
I did a cleanup, sprayed well with the red "varnish", new bearing
and added wood and epoxy shims to the loose bobbin.
I get just a little imbalance growl when the load gets up to about
10 to 12 amps on one side.....man, I'm happy with that !
This unit came with the AVR and "modern" rectifier.  Whoa, almost
forgot the DIGITAL volt/frequency meter. What will those Indians
think of next ??
Just though you guys might like an update.
Carry on,
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
M61hops
Re: 7.5 st update
« Reply #1 on: September 25, 2015, 09:28:22 AM »
Thanks for the thread Gary.  I have wondered if the growl in my 7.5 was caused by a slightly loose winding and you have seemed to confirm my suspicion.  I will pull mine apart before I run it much more.  It just doesn't seem right that it would make this noise just from the magnetic flux, something with mass is moving slightly  :-\ .
