Author Topic: what I found so far...  (Read 2293 times)
32 coupe
  • "Doc Johnson" on call !
« on: September 19, 2015, 06:04:08 PM »
What started this is......new 7.5 st
After unloading I noticed a tiny "knock" when turning
by hand. Not terrible by any means but it was there.
It spun good but a barley noticeable knock.
After bolting up and loading it with 2 space heaters
, one on each leg, I noticed the imbalance growl.
I have it apart now. The front bearing, sealed but with
the inside cover off and rolling around the shaft. It feels
OK but I will replace it. Back bearing seems fine.
The knock you ask ?  One of the wound bibbins is a ltttle
loose on its mount...
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
Re: what I found so far...
« Reply #1 on: September 19, 2015, 06:14:44 PM »
Glad you found the source of the noise, Gary!
