Well, I just finished a frustrating afternoon learning what NOT to do. I went down an bought some 1/2" lag screws, drilled into my floor and bolted that baby down tight. Then I fired it up. To my astonishment it stayed in place but vibrated enough that I could see my floor moving at one corner of the frame! I dropped the rpm down to around 525 and most of the nasty motion went away.
At this point I really considered using a smaller generator pulley just to keep the rpm's down, but then I'd probably have governor problems on top of the horsepower loss.
I finally decided to put my casters back on. When I initially tested this whole rig in my garage....on the casters....it behaved very well, so why not just put them back on and see what happens? This took about two hours of jacking and reattaching the things before it was ready. I fired it up and it seemed to be okay at first, then started the infamous "kangaroo" dance. I hit the fuel cut off and sat down for a while to ponder.
My original test runs were done in my garage, with a CONCRETE floor. Although the generator was on casters, the concrete gave a smooth, firm surface. Even though the floor is very slightly sloped for drainage it sat in one place. Hint: the floor had no "bounce".
Okay......now the shop floor.
First of all it's not level where I set the generator......had to shim one rail end about .035" or so.
Second, it may be a dandy wooden floor capable of supporting great weight.....but it's still flexible. So any repetitive vertical motion is "amplified" minutely until it mimics a trampoline, and the engine starts hopping. I would imagine the action would get so bad the whole thing could leave the floor an inch or so.
I'm going to fall back and regroup. I considered cutting a hole in the floor and pouring a yard of concrete, but there might be another option. I have a small driveway approach pad behind the shop and the rig might be happier there, ensconced in its own little shed!
LATE PM UPDATE: It's the floor.......no doubt about it now. I rolled the entire unit to a portion of the shop floor that is known to be reasonably level and rigid (or so it seems). After starting, the engine came up to speed and seemed to be doing better..........then I felt a slight thumping begin under my feet and within seconds the engine was dancing to its own beat. I shut it down and rolled it back into the corner.
Tomorrow I'll fire up 'ol Gerty (fork lift) and move the Listeroid out to the concrete pad behind my shop. I'm really curious and want to start/run it again while it's sitting on the slab with just the casters. It might make all the difference in the world and all I have to do is build a small shed. Stay tuned!
