BruceM, thanks for the kind words.
I agree Glort, personal preference has a lot to do with it.
I just love the sound of the engine ticking over at the slower speed. Like a Swiss watch.
And why make more speed/HP than is needed for the application.
As long as the engine is sufficiently loaded to generate enough heat for clean combustion, things should be ok.
I agree that at a certain point damage can be done depending on the engine. Such as...
A] not enough splash lube
B] lugging and pounding of the rod ends due to lack of flywheel inertia
In essence, size the pulleys and engine speed according to your loads.
If I ran the Listeroid at 650 RPM it would only be loaded to ~25%. Not my preferred situation.
