So, I still cant get the bush/bearings out of the castings, so I am buying a hydraulic press. (I figure I can use it for some other things in the Blacksmith Shop).
I went to slide the bearings back on the crank, to see what the fit up was like for use as spares in the future. Well...they wont slide down to where they need to be!
Aparently, there are some buggered up spots on each end (mid ways down the shaft), that wont let the bearings to pass. I assusme this happened during removal of the flywheels/bearings etc.
The engine was patially disassembled when I got it.
So...I figure the best thing to do would be to put the crank in a lathe and turn it? to take out the problems. I have a freind with a hot rod shop who has a lathe.
I dont want to reduce the diameter down unless I have to...just take off the high? spots that are causing the problems. I know there are undersize? busings, but I would
rather not go that route unless necessary.
So what are the tolerance specs for the crankshaft? Suggestions? And while I am going to be at his shop, what diameter metal blank, would work best for pressing out the bearings?
