Hello Dave:
I am 2 years into off-grid here. Started with gen set, batteries, inverter. Added solar a few months later. It is a 24V 4000W system.
Using a 6/1 listeroid with a 3kw generator. (It is a now unobtainable PMG, but a 5Kw ST seems the most common choice.)This combination has proved to have sufficient power for both house and shop. I can run table saw, planer, bandsaw, etc. with no problem. biggest single draw is a 3/4Hp deep well pump.
We also operate a fridge and 2 freezers in addition to all the usual stuff.
We start/stop manually, and I am always somewhere on the property when the engine is running.
The engine sits in a partially enclosed shed. Too far from the house to use engine heat, and in any case, a two hour charging run will not fully warm up my 30 gallon cooling tank.
On days that require charging, a 2 hour run is sufficient to put my batteries at 100%. In the Pacific Northwest, our use is about 350 hours a year.
After the initial tear-down, reassembly, and sorting out, the system has been trouble free, except for the odd time I have forgotten to fill the
fuel tank!
We are in a rural area. There is grid electrical service available, but we chose to disconnect. There are frequent winter power outages here, several neighbours have standby generators.......you can tell when the power is off from the noise of their Modern, high speed gen sets. Our Listeroid is not audible at their homes though, and sometimes the neighbours drop by to hear (and watch) it run.
As well as the K.I.S.S. practicality, fuel economy, ease of repair, there IS the "romance" of the Lister.....you WILL get caught up in it.
I had to buy a real Dursley.......for no good reason except as a "standby" for the JKSON.
I'm sure you will hear from others regarding your questions, many have more experience than I.
Hugh
Feel free to PM me for more.
