Don't forget to check out the LEF Gallery! Exclusively for LEF members, an ideal alternative to Photobucket, Flickr, etc. It's FREE, and best of all totally AD FREE! Just click the link!
3/4" heater hose is adequate for a thermosiphon setup.
+1 for Mike's method. His part number for the NAPA gasket was very helpful. A friend with a plasma cutter made a 3/8 steel plate as a spacer.
Mike,Again, good work !We have found a 1/8" weep hole will really help in the t-stat.Makes the system easy to get rid of hidden air pockets.Gary
+1 on the hole(s). I've gotten better performance (less hot/cold) going up in size from 1/8", now use two 3/16" holes on my thermosiphon setup.
