Author Topic: Water in jection decarboning  (Read 29294 times)
Tom
  • Green power is good.
Re: Water in jection decarboning
« Reply #60 on: June 22, 2015, 07:38:20 PM »
Yup the injector attaches just fine upside down.
Tom
Mr X
« Reply #61 on: June 23, 2015, 03:46:39 PM »
Yah I know and I spray wvo eather  into my rad or at the wall and I can't see if it is dribbling. And there is no gauge.
6/1 PS Jkson soon to run WVO,  3 hp Petter, 3 Honda 5 hp, 1 weed eater, Live off grid, Now a dog farmer
« Reply #62 on: June 24, 2015, 03:45:13 PM »
I made my own tester with a grease gun as the pump.  Worked great and already threaded for 1/8 pipe threads.  I cut the end off of a spare injection line to get the fitting, then drilled a 1/8 thread plug and JB welded the cut tubing into the plug.  The only problem I had was in using vegetable oil; the seals in the grease gun failed after a year and it had to be replaced.  I suggest flushing it out with mineral oil after use if you're using veg. oil.
