Good theory, Tom. I don't think the spark is intermittent, since the smartplug has the same trouble, but I'm wondering if the spark is adequate to get ignition. From what I've read, propane demands a high power spark system, even more so for a lean mix. I also wonder about sparking in the indirect ignition chamber...where it could be even leaner. I know the woodgas guys got it to go but woodgas is very different than propane.
I might try the CDI ignition hardware I have.
I've got the CA110 mounting plate secured to the intake manifold, fiddling with the plumbing now.
I did take apart the CA55; there is no rubber diaphram, instead, the diaphram is a roughly 2" diameter plastic and aluminum piece with a single plastic ring that rides in a cylinder. It has a metal projection that is the main metering element, and a big 2 diameter spring pushes it closed, acted against by the intake vacuum. The internals were clean, new, unworn, smooth. I saw nothing that led me to believe it was damaged or defective.
I hope to have the CA110 going this weekend. It's so huge, an intake restriction will surely be needed!
