Gary, thanks, I did look up the specs. I guessed at about 14 degrees BTDC for the cam, which puts IP firing 5 degrees before the lobe tip. I'll find out tomorrow how it turns out.
Tom, yes, I run a bit retarded most days, myself. Noticeable lack of pep...
Thob, yes, there's always the wasted spark method via magnet on the flywheel (at twice the power consumption), but I've grown attached to using the IP cam follower.
I pulled the camshaft and moved the IP cam lobe to where I think should be for diesel operation. I needed to pull the flywheel to fix an oil pump plumbing leak anyway, and I wanted to raise the compression ratio back closer to 14:1. So it all came apart, again.
I was going to use 38ac's set screw method for testing purposes, but I could not get even a cobalt bit to drill through the cam lobe collar; it was that hard! By that time I was pretty tired so out came the JB weld. I think that should be adequate without welding since I have no IP.
Tomorrow I'll get it all back together and see how I did on the cam lobe timing. Then I'll find out if I must add circuitry for retarded starting timing when I get the running timing properly advanced.
