Jtodd:
The people you are dealing with are @#!$% .
Want brands are part number do they ?
Tell them you would like to see a list of Crompton analog panel meters...
Tell them you would like to see a list of Hammond, Ralston, or Stallin brand electrical enclosers ( Nema 4 style ).
Yes, I've not found much enthusiasm for my project with the various parts desks I've encountered. I don't represent a lot of "repeat" purchases for them, so most try to hustle me out as quickly as possible to make room for larger customers.
So, you've given me a good number of places to start with Crompton. I really just need some manufacturers and then Google and I can have a nice afternoon hunting down the part numbers. I've already got some nice aluminum NEMA enclosures courtesy of the US government's surplus process, and I'm happy to make my own wire panels and everything else - I'm just having problems with gauge sources for the panel.
The Crompton stuff looks very nice, but the list prices made my eyeballs jump out of my head on springs (>$500 for most of the nice gauges.) I'm an "analog" kind of guy, and it seems that the analog gauges are actually more expensive than the digital stuff, at least for new. eBay has got some interesting leads on various protection relays by Crompton, but none of them are quite right and I'm not sure if I can even adjust the mhz for use with my slower setup since most of them are configured for fairly fast RPMs. A combination of gauge and over/under protection relay seems to be a pretty tough mix to find as a single component, so possibly they will be separate elements in the control panel. This would allow me to make a reasonably nice-looking panel with consistent gauge appearances, and then hide all the ugly protection relays inside the enclosure. (I don't focus on appearance, but if it's a mostly equal choice I'll go for a nice presentation.)
Gauges and alarms/relays needed (assume "alarm" means a relay):
AC voltage (over/under alarm)
AC amperage (over/under alarm)
DC voltage (no alarm needed)
DC amperage (no alarm needed)
RPMs (over/under alarm)
Temperature, water jacket (over alarm)
Temperature, exhaust pyrometer (no alarm needed)
Temperature, oil (over alarm)
Temperature, fuel@pump (no alarm needed)
Temperature, fuel@main tank (relay needed)
Hour meter (no alarm needed)
Fuel gauge, primary (no alarm needed)
Fuel gauge, start tank (no alarm needed)
Links I found:
http://www.k-tech.com/Crompton/Crompton-Index.htmIn any case, count me in as being interested in the parts list as well. Anything helps.
JT
