And Tom taught me that you lean DOWN on the handle, to build RPM's instead of using your back to lift UP. I get it spinning and do 2 "creaks" of the injector before I release the decompression, and then have 1 grunt to pull it through the compression stroke. If above 40F, it fires, otherwise, I have to crank through 1 more compression . If it won't fire then, I take a break for 5, and start over. Got to look into using a can of sterno to keep it warmish overnight, or something. Maybe a diesel smudgpot ? I don't have the electric to use to keep it warm.
