Author Topic: What's the adjustment screw below the injector pump for? 8-1  (Read 2843 times)
jimboz
There's a screw and locknut below the injection pump which probably applies pressure to the pump tappet, what's it for?
thanks,
Re: What's the adjustment screw below the injector pump for? 8-1
« Reply #1 on: June 01, 2014, 03:39:11 AM »
I believe you are talking about the alignment guide for the tappet. The pump tappet is a roller-bearing type and not designed to rotate like the valve tappets... it must be held in proper alignment to the cam lobe.
jimboz
« Reply #2 on: June 01, 2014, 03:52:49 AM »
Next time I'd like a quicker answer :)
BTW, head studs fit great, thanks.
« Reply #3 on: June 01, 2014, 03:58:55 AM »
My pleasure!
Best of luck!
