Author Topic: 8-1 Startomatic Instruction Book/Parts List  (Read 6928 times)
jimboz
« on: May 17, 2014, 02:16:47 AM »
Does anyone have a 8-1 Startomatic generator parts list?   I'd like to know the part numbers, sizes and grades of carbon for all the brushes.
Thanks,
Re: 8-1 Startomatic Instruction Book/Parts List
« Reply #1 on: May 17, 2014, 04:13:59 AM »
I have one of the 8/1 SOM machines here with a label affixed listing the brush sizes. I can take a look at it tomorrow sometime if you like. I should also have the manuals but will have to dig a bit to see if the correct ones are scanned.
jimboz
« Reply #2 on: May 17, 2014, 02:52:50 PM »
That would be great, all I have and can find is for the smaller machines.  Do you know of a supplier?
thanks,
DirtbikePilot
  • Spinning flywheels are cool....
« Reply #3 on: May 18, 2014, 01:25:41 AM »
I got some brushes for my parent's 6/1 startomatic here. http://www.stationaryengineparts.com/Start-O-Matic-spares/
Currently no listeroids, sad........ very sad.....
Just some other antique engines ranging from 40 pounds to 33,000 pounds each.
listeroil
« Reply #4 on: May 18, 2014, 03:07:36 PM »
Jimboz
Heres a sheet from a Lister book. The DC brushes are 1 inch long. I would not recommend buying genuine Lister brushes they cost a fortune.  I get mine made by http://www.carbonbrushes.co.uk  They cost less than £10 each and David the boss is easy to deal with.  I actually get mine made 1  1/8 inches long because the commutator and sliprings have been skimmed and I feel they need a bit of extra length.  There are 2 types of alternator used on the 8/1 engined SOMs  One we call the fatboy which is the earlier type and has 6 DC brushes inside it.  4 main DC brushes and 2 smaller ones for the auxiliary field winding.  The other type is the slimboy and they only have the 4 big DC brushes and no small ones.  The large DC brushes are the same for both types and the AC brushes fit both types as well.
Mikck
« Reply #5 on: May 19, 2014, 01:12:45 AM »
From my "fat boy" 4.5kW SOM - total of 10 brushes
Slip Ring Brushes 4 each 20mm x 8mm x 20mm, grade SB5,  (part number 64-7265)
DC brushes 4 each 3/4" x 3/8",  CM6, (part number 64-8475) ,  2 each 3/4" x 1/4", C4, (part number 64-8477)
Bearings: drive-end  335, commutator-end MS11
jimboz
« Reply #6 on: May 19, 2014, 01:05:10 PM »
You guys are the BEST!.  Mine's a Fatboy too, anyone recommend a brush mfg in the states?  If not i'll go with your place Listeroil.
Thanks again.
listerdiesel
« Reply #7 on: July 17, 2014, 05:43:48 PM »
I've just bought a 4.5kVA SOM alternator, but those bearing numbers don't seem to match up to what I have, or at least one of them
MJ1-1/8 bearing at the commutator end, haven't got the drive wheel/flywheel off yet so don't know yet what that one is.
Are there other variations?
Peter
listerdiesel
« Reply #8 on: July 22, 2014, 04:14:53 PM »
Drive end bearing is a 6307 Metric series bearing, not what I expected to find!
Shielded on one side only.
Peter
listerdiesel
« Reply #9 on: July 23, 2014, 06:25:39 PM »
No comments?
Nobody looked at their bearings at all?
Peter
