Author Topic: TL / TR engine pistons  (Read 4001 times)
barry100
« on: April 11, 2014, 01:45:16 AM »
Hi All
I have a few TL engines to rebuild, will TR pistons be any good (same bore) and whats the story about 3 and 4 ring pistons? when  3 ring piston used are the cylinder bore clearances reduced or are they just used in higher speed engines, any help would be great
Barry
Re: TL / TR engine pistons
« Reply #1 on: April 11, 2014, 03:43:30 AM »
To my knowledge all replacement pistons have been 3-ring and we always used the same book clearance values. Same unit used for both TL and TR.
barry100
« Reply #2 on: April 14, 2014, 11:59:30 PM »
Hi Dieselman
Thanks for the info'
Barry
barry100
Re: TL / TR engine pistons rings
« Reply #3 on: June 14, 2014, 04:14:46 AM »
Hi All
Another question about the TL/TR piston rings, will a set of rings for the four ring piston fit a three ring piston leaving out the bottom oil ring.many thanks in advance
regards Barry
« Reply #4 on: June 14, 2014, 02:33:02 PM »
To my knowledge, that is affirmative. These are normally supplied and sold as assemblies though. When you purchase a new piston, it comes with new rings.
