Author Topic: British Standard O rings?  (Read 3288 times)
Reno Speedster
« on: June 30, 2006, 12:37:55 AM »
I have been trying to get my Listeroid back together but I have run into a problem with the O-rings for the sleeve.  1/8 dia. is too small and 3/16 is too large.  I suspect that they might be British Standard but I can't seem to find them.  so, 1) can anyone tell me if they are actually British Standard (and what size they are) and 2) can anyone tell me where to find them?  Thanks
Morgan
« Last Edit: June 30, 2006, 12:39:52 AM by Reno Speedster »
Re: British Standard O rings?
« Reply #1 on: June 30, 2006, 02:41:45 AM »
Might be metric...
snail
« Reply #2 on: June 30, 2006, 03:37:05 AM »
What makes you think this would be easy? :D I'm an english rubber technologist and this system still drives me mad.
Try:
http://www.afmusa.com/doc_generator.asp?doc_id=3731
And best of Britsh luck!  :D
Brian
listeroidsusa
« Reply #3 on: June 30, 2006, 04:13:13 AM »
All of the engines that use liners are metric. I've got some o-rings  but I'll need to measure them. I think they are 4 mm, or approximately .157". A 5/32 oring is .15625 and would work well if the size is indeed between 1/8" and 3/16". I'll have to check Monday because I'm about to leave for the Denton, NC engine show.
Mike
« Reply #4 on: June 30, 2006, 07:27:38 PM »
Valve guids and stem are also commonly metric are they not Mike?
