1. Remove the radiator cap and cut off the little metal check valve flapper plate in the middle of the radiator cap(round ring that points down into the radiator when installed. This will allow fluid to flow easilly in and out of the overflow hose barb on the radiator filler neck. Connect a hose up to the bottom of the overflow tank like in my drawing.
2. Drill a hole in the highest point in the top of the top tank and solder in a brass hosebarb. Plug on a hose and run it up to a small bottom fed overflow tank like in my drawing.
Mounted like this, water in the tank means the radiator is full...
Hello ronmar,
Post #1
Your help has been a huge relief for me and I thank you and everyone on this forum for the good advice.
I have the radiator raised sufficiently for good syphon. I have the overflow tank raised above the radiator with a hose connected to a hose barb in the top of the radiator. Here is a link to 4 - radiator photos. <iframe width="480" height="360" src="
http://s1172.photobucket.com/user/Aristotle-Rand/embed/slideshow/"></iframe> Will you please sir explain to me
1. why I need to remove the check valve flapper plate in the radiator cap and give me a visual description of it?
2. Why do I need fluid to flow easily in and out of the overflow hose barb on the radiator filler neck. The hose barb that I am using for my overflow tank is not associated with the filler neck.
3. Does my cooling system need to be a pressurized or a non-pressurized system?
Post #2
Okay, I just ran the generator for 30 minutes under a 5,000 watt load (2/3s of its rated 7,500 watts). The temperature at the fluid outlet flange of the engine went up into the 220s and a signifigant amount of water was bubbling out so I shut her down slowly removing the load.
It took a few minutes for the temp to get that high plus I was using straight water not 50-50 (because I was testing out a newly soldered fitting.
Also, I had the lid to the overflow tank open because I wasn't sure whether or not the system needed to be pressurized (as if a plastic bottle would pressurize it).
Last but not least I was using a hand held infrared thermometer which may be off by a few degrees.
The good news is that I believe that syphoning is taking effect. I am just wondering why I lost fluid.
Post #3
Interesting phenomenon has occured. The temperature has cooled down enough to allow the fluid in the overflow tank to flow back into the radiator but it will not. I added water to the overflow tank but it is not entering the radiator. The radiator must be full and therefore not losing water. Funny, I saw a decent amount of water and steam coming out of the overflow tank.
Thanks,
Jim
Best Regards,
Jim
