Hi Tugger
Sent a reply before but somehow it went off into cyber space.
I went with (A) and just got it in the shed on Wed. I installed an electric start between the flywheel & the gen head. You might want to consider it. Have you tried to turn it over by hand? Whew! And with getting that set up, it will take a few muscles or build them, I'm not sure which. I have the same engine 12/2 Jkson and the 10kw head. I like the idea of Listeroidsusa's with the washer/dampers cut out of bailer belting. I just may pull my installation apart and add them for added isolation. It all helps.
If I knew how to add picts (like yours) to the reply section I would. I tried copy & paste, no go, came out blank. Then tried Insert...the same. How did you do that? Any suggestions welcome. tks binnie, & congratulations on a nice looking machine. I hope it serves you well.
Let us know your plans, aims, etc.
