Author Topic: off topic electrical question  (Read 7564 times)
« on: November 13, 2013, 05:48:03 PM »
« Last Edit: September 02, 2019, 03:05:57 AM by 38ac »
Re: off topic electrical question
« Reply #1 on: November 13, 2013, 06:03:13 PM »
LED?
Casey
« Reply #2 on: November 13, 2013, 06:08:15 PM »
You need a "back  EMF" diode installed.  about a 1,000V, 1 amp should do it.  Google how to wire it.
BUT - Will those solenoids take the duty cycle you are giving it ?   I thought they were good for just 10 seconds at a time or the coils overheat.
« Reply #3 on: November 13, 2013, 06:25:01 PM »
« Last Edit: September 02, 2019, 03:06:08 AM by 38ac »
« Reply #4 on: November 13, 2013, 08:20:02 PM »
I think these solenoids were used in early golf carts for throttle interlock control.  No foot peddle would leave the power off to the motor control unit and the motor.  I'm guessing again but it may have had to do with phantom power use.  Anyway, it takes minutes to get from one stroke to the next so these solenoids would be active all the time the throttle was being activated at the most modest of levels.
Casey
« Reply #5 on: November 13, 2013, 08:28:05 PM »
There are continuous and intermittent duty versions of that solenoid. Perhaps moving the wire to the unused small terminal would resolve the issue. That terminal was used to supply full voltage to the coil while cranking.
listerdiesel
« Reply #6 on: November 13, 2013, 09:22:10 PM »
Something like a 1N5401 wired inversely across the contactor coil should snub it OK, or you could use a Varistor, but diodes are cheap.
Voltage rating doesn't need to be huge as it is conducting when the voltage is positive, just needs to withstand the 12V.
We use a lot of Albright International DC contactors in our chargers, 80A up to 200A and they all have 28V continuously rated coils and the driver board has a 1N5401 across the output to the contactor coil, never had one fail.
Wiring inversely means that the silver band end of the diode goes to the +ve feed to the contactor, unbanded end to the -ve side.
Peter
Thob
« Reply #7 on: November 13, 2013, 10:38:18 PM »
I agree with using the diodes.  I usually buy the 1N4001 - 1N4004; they are 1 amp in various voltages.  1N5401 (and up) are 3 amp, and hence a little heavier.
For quick, easy availability of parts I'll stop by Radio Shack.  Something like these should work:
1N4001: 276-1653 (25 pack)
1N5402:  276-1143 (each)
Otherwise, I buy online either from Mouser (www.mouser.com) or Digikey (www.digikey.com).  There are lots of other good online sources as well.  Mouser is "just down the road a piece" from me, so ground shipping comes overnight (but not free).  It's too far to drive, though.
In use, the diode will be reverse biased (off, non-conducting).  When the magnetic field collapses, the voltage will reverse and flow thru the diode, which will absorb the spike.  The spike will not only burn out bulbs, but also arc across switch contacts and eventually burn up whatever is controlling the solenoid.
Now: for the curious, what are you doing with the solenoids? What is this machine?  Pictures?
« Reply #8 on: November 13, 2013, 10:43:59 PM »
« Last Edit: September 02, 2019, 03:06:21 AM by 38ac »
« Reply #9 on: November 14, 2013, 12:32:14 AM »
Interesting, this may also explain a problem and provide a solution to an issue I was having with burning out some instrumentation on a John Deere generator install. Every fourth or fifth time we would start up, the electronic gauges were burning out... replacing them was getting quite expensive! I suspected something related to a surge from the starter solenoid, but the spike was too momentary and fast to capture any reading with my equipment and it seemed to be erratic in that it didn't happen every time the machine was cycled on and off.
Thanks guys!
« Reply #10 on: November 14, 2013, 12:37:37 AM »
Hey Butch! Love your setup! When can you come over and chew up some wood for us?  :laugh:
I basically am getting too old to cut and chop wood anymore without paying the price with heavy aches and pains. Looks to me like you have this thing figured out!  I had to burn wood this fall in Alaska and hand cut and chopped about a cord or so... glad to be going back to Kansas on Friday before it gets sub-zero around here and the real work begins!
« Reply #11 on: November 14, 2013, 02:34:17 AM »
« Last Edit: September 02, 2019, 03:06:38 AM by 38ac »
Oiler
« Reply #12 on: November 14, 2013, 10:45:32 AM »
Why not use 24 volt bulbs.......or two 12 volts in series?
1962 CS 6/1 for cutting firewood.
Armstrong Siddley AS1 for sale.
1937 Lister D
1918 Lister L
listerdiesel
« Reply #13 on: November 14, 2013, 11:08:50 AM »
Better cure the problem at source than try and mask the effects?
Peter
