Hi all and to our southern neighbors, hope you had a great Turkey day. Since my last post, I have confirmed the camshaft timing (as per the excellent video courtesy of 38AC), set the spill timing to as close to 20' BTDC as I could manage and bled the fuel system yet again. I managed to cobble a temporary stand together out of pressure treated 6X6s, and bolted the whole thing together. So with all that done, and some oil in the sump, it was time for this.......
[youtube]http://www.youtube.com/watch?v=BOHqgDUTZFc&feature=youtu.be[/youtube]
Not quite the result I was hoping for. So it was off for some lunch, a couple of chores and small jobs for my sweetie, some more reading on here, and......
[youtube]http://www.youtube.com/watch?v=uhkaSfFMXRk&feature=youtu.be[/youtube]
Again, not quite the stunning success I was hoping for, but success none the less. At least it was not some kind of out-of-control jack rabbit which I attribute to the flywheel balancing I went through. It is still a little bouncy, and I have some ideas, and certainly a more robust stand wont hurt. So I kept bleeding, restarting, rechecking and finally ended up with this....
[youtube]http://www.youtube.com/watch?v=R15HKedrJqA&feature=youtu.be[/youtube]
Note the use of volunteer muscle power, a heat gun and lots of encouragement fluid
Still not where I want to be. It almost seems like it is missing occasionally. I have a bicycle computer with cadence function that I think will act as a tach so I can check the speed. I don't know if it is running fast enough or not. I also don't know about the injector leak-off line going to the top of the filter, but that seems to be the only way to hook everything up and not have leaks.
All in all, not the Listeroid Nirvana I had been hoping for, but sweet success. I am okay with that. Lots more to do, and certainly no shortage of ideas. Thanks to all for all the help and suggestions.
