Just tried my CS8/1 after making a simpler alternative to the Utterpower modification. All I have done is make a wire link so as to movethe spring away from the fixed end, such that the adjustment rod can be wound almost right into the crank. It cetainly seems to work better, and for no more cost than a few inches of galvanised wire. It probably doesn't look marvellous, but with my SOM set mounted the way it is it can hardly be seen, even if you know to look for it.
Seems to have been half an hour well spent
Ian
