Author Topic: How are you pre-heating your WVO before the injector  (Read 18006 times)
« on: September 26, 2013, 04:15:46 AM »
Hi Everyone,
This is for my GM90 Listeroid:
I now have my WVO fuel tank mounted and the fuel supply lines are divided by a 3-way ball valve close to the Injector Pump.
I am ready to set up my VO pre-heating system and I would like to know what systems have worked for many of us members.
In my inventory I have some 30" long ni-chrome heating wires (120 vac).
I also have a small plate heat exchanger which I could tie into the coolant lines for a supply of 180f heat if needed.
My initial plan was to just heat the injector line with the heating wire an see how that worked.
How are you doing it ?
Suggestions welcome.
cheers,
bschwartz
Re: How are you pre-heating your WVO before the injector
« Reply #1 on: September 26, 2013, 05:30:30 AM »
Veggie,
I ran my listeroid 6/1 for several years with a nichrome injection line heater like you are suggesting, and preheating the oil by wrapping the supply line (from the tank to the selector valve) around the exhaust.  http://listerenginegallery.com/main.php?g2_itemId=6626
I had the head off several times over the years for leaking head gaskets (original type) until I started using the gaskets-to-go type.
Each time I had the head off, I never saw significant carbon buildup, so I'll call my heating method successful.
-Brett
jfgalaup
« Reply #2 on: September 28, 2013, 08:19:14 AM »
Veggie,
Hello,
I use VWO with non pre-heated fuel line.
I added only kerosene (1/5° of volume).
I beginn running the 6/1 (Vidhata) with diesel. After 5 minutes, via a by-pass, the Listeroid run well with mixture VWO (4/5) and kerosene (1/5).
10 minutes before shutting down (at full load), I closed the mixture-line and the Listeroid run only with diesel.
That procedure allow a cold-start without pre-heating in any weather and in any circumstance (but I'm living in Tahiti... French Polynesia, near Bora Bora).
Best regards.
jfgalaup
« Last Edit: September 28, 2013, 08:26:56 AM by jfgalaup »
listeroil
« Reply #3 on: October 01, 2013, 05:23:11 PM »
Veggie
I use no form of preheating at all. I use liquid WVO and start and stop my engine on it. I have fitted a thermostat in the water system to get the engine up to temperature quick and keep it there. I am not sure if I could hand crank the engine to start on WVO. I have a SOM with electric start and sometimes it does take a bit of cranking.
Mick
tyssniffen
« Reply #4 on: January 08, 2018, 04:57:19 AM »
this is an old thread, but I'll throw in here.
I do exactly what jfgalaup does, I run my WVO along an extended exhaust pipe, in an aluminium tube for good heat transfer.  I have the exhaust and tube wrapped together.
what I wanted to see if I could get a reply about was the comment about 'not seeing much carbon build up'...  I have a TON of carbon build up when I run WVO... could it be that I'm simply not getting my WVO hot enough??
tyssniffen
« Reply #5 on: January 10, 2018, 11:58:34 PM »
wow. you're blowing my mind here.   this is a bit much to take in.
just to answer your early questions quickly, before going back to read again:
I get carbon build up on my injector... to the point where I don't seem to be getting fuel injected the next time I cold start (after shutting down on store-bought diesel).  I pull the injector and see the baked on, built up black gunk... I clean it off, put everything back together and it gets running.
so, gotta figure in the cylinder too.
and, while my WVO isn't perfect see-through stuff, I've been running veg in my Dodge for 10-12 years, and I'm putting this better stuff in my lister than I do in my truck.
Now, I have also just started doing some chemical adding - someone gave me some gasoline with a bit of diesel mixed in, so I'm doing about a cup per gallon... so, what, 1 in 8?  Do you think would be a problem, or a solution?
Tys
« Reply #6 on: January 11, 2018, 02:11:24 AM »
+1 on adjusting your injection timing-  this helped with the injector deposits I got on biodiesel and I suspect it would on WVO, as Glort recommended.  I don't have experience with WVO, but I think the physics (thermal dynamics) of what Glort says on oil heaters is correct.  Especially with a low fuel flow rate like the Lister CS, there is no doubt that the injected oil will be injector body/nozzle temperature regardless of incoming temperature. Ditto the fuel injection pump.  Heating is to have fuel flow in the supply lines.
Watch your loading-  keep it at full operating temperature...don't let it run at less than 1/2 full load.
+1 on water injection-  beats carbon scraping by a mile.  Spray bottle into the intake of a hot engine at every 3rd or 4th 8 hr lube service or when the knock after starting sounds more pronounced works for me.   A nice black cloud comes out of the exhaust.  Water injection seems essential when burning any fuel that's leaving crud on your injector (and elsewhere less easy to see).
« Reply #7 on: January 11, 2018, 02:27:06 AM »
 There were carbon deposits on my injector, similar to what you describe, when running alternative fuels. I never did resolve the issue and gave up. Diesel prices got cheaper too.
tyssniffen
« Reply #8 on: January 15, 2018, 04:58:32 AM »
I will work on moving the timing up, for sure!
are you saying you have rigged up a *water injector* somewhere?  can you post a photo?
and /or
into the AIR intake?  and just like, a spray from a squirt bottle??
« Reply #9 on: January 15, 2018, 08:35:19 PM »
I've been using a spray bottle, I wait till the engine is well heated and running at load, then spend a couple minutes spritzing the intake.  If I time it right, the intake pulse instantly atomizes the stream, and sucks it in. Otherwise, it dribbles in, and I always let the engine run a while afterwards to dry all the parts out, before shutting down.
tyssniffen
« Reply #10 on: January 15, 2018, 08:58:19 PM »
cool. so you're pulling off the filter while it's running?
I'm going to try this, AND work on changing my timing.
« Reply #11 on: January 16, 2018, 12:45:10 AM »
I also pull off the air filter for the spray bottle treatment. As Glort explained, that's not necessary, but i find it satisfying.  I do it while pumping up my 500 gallon air storage tank, usually after a pumping water and laundry.
I do about a pint, as fast as I can hand spray the bottle.  The engine doesn't stumble at all.
I intend to do a proper water injection system on of these days.
