Hi Brian. My cart was from a tractor scrapyard. It had a pump on it that the owner was keeping and the cart itself was in poor shape, they had backed over it with the loader
I spent a couple weeks bending/cutting/welding to get it right. I had a thread on Smokstak about it and my pics as I was building it are on the listerenginegallery at the top of this page under my screen name.
Thoughts:
1) Big wheels roll easier than small wheels
2) Pnuematic wheels roll easier than steel wheels
3) Lister never made these portable but did skid mount them
4) A working engine will need a much larger cooling tank or a rad assembly
If I was to do it again I would either skid mount or make a drop frame cart. The drop frame has a few pluses-it puts the cooling tank at a better height for functionality while lower the center of gravity of the whole unit, the drawback being decreased ground clearance-not a problem unless you are loading onto a trailer or moving over very uneven surfaces.
The genny can be mounted on the front of the cart and a double pully assembly could also drive a hydraulic pump for a woodsplitter etc..really anything you could imagine.
Think long and hard before you commit to a design. When I first got my 6/1 I mounted it on a 4'x4' trailer to make it towable.
Good luck, I assume it was you who emailed me. Where are you located ??
P.S. For fuel on my big Ruston what I did was repurpose a 20lb bbq tank. After safely devalving, purging, venting and praying I drilled a small hole in the bottom and welded a short 1/4" pipe coupling on. This is your outlet, put a valve on it. At the top I put a close nipple into the hole then a 1/2 x 1/2 x 1/4 tee was screwed on sideways so that the 1/2 and 1/2 ends were verticle and the 1/4 hole was horizontal. The top 1/2 hole gets a vented cap put on and its for filling. The 1/4 hole is for your pump return line back into the tank. I made a small bracket out of steel channel and welded the open side to the tank vertically then welded the bracket onto the top of my cooling tank..voila'...I dont condone welding on propane tanks...or drinking too much Rum...or pre marital sex...or sticking your tongue on a 9v battery or...
