Author Topic: 3 phase 120/208 to 120/240 single phase possible?  (Read 4447 times)
fred75
« on: July 21, 2013, 01:03:56 AM »
Hello, I have a 20kw generator coupled to a lisert ha3 motor. This is a three phase generator 120/208V. General Diesel brand. I need 120/240 single phase. Is that possible?
Sorry for my bad english
thank you
fred75
Re: 3 phase 120/208 to 120/240 single phase possible?
« Reply #1 on: July 22, 2013, 12:04:59 AM »
anyone know if we can do one phase with a three phase generator? Maybe you'll tell me that the answer is already on the forum, but I need your help because I'm not comfortable with English. So, my generator is for my farm and there are fan on 120v and I do not think that can work with the 3 Phase because its single-phase motor, I would not break them.
thank you kindly help me
« Reply #2 on: July 22, 2013, 01:40:57 AM »
I think you can use a single phase of your generator, to drive small loads, but I don't think you can pull 33% of the rated power from only one of the 3 windings.  And it will waste a lot of fuel for a little bit of power.
Thob
« Reply #3 on: July 22, 2013, 02:39:04 AM »
Each of the three phases can supply a 120V single phase load between the line for that phase and neutral.  If all you have is 120V loads, it is simple a matter of balancing the loads so that each phase has (approximately) the same load.
If you need to power 240V single phase loads, there may be several options.  Some 240V loads will function quite well at 208V (read the label on the load to know); if that works you get 208V between any two phases.  Again, you need to balance the loads across the phases.
Some generators can be rewired for 120/240V operation - although they typically can produce 2/3 the power they can produce on 3 phase.  If the generator only has 3 or 4 leads, then it probably cannot be re-wired.  If it has 12 leads, then it most likely can be re-wired.  Check the generator data plate to see if it has a designation for the number of leads.  To properly re-wire it, you'll need instructions for that particular generator.  For a generic idea of how it can be done, look up zig-zag or double delta; those are the names given to two different methods of re-wiring the generator.  Post pictures and/or the complete model numbers and someone here might be familiar with the generator to know how it can be re-wired.
buickanddeere
« Reply #4 on: July 24, 2013, 04:04:29 PM »
Actually 57.7%, not 2/3 of capacity when a 12wire gen set is wired from 120/208 three phase to 120/240 single phase.
