Hello Mike,
Thanks for the good advice. When you speak of SS all-thread are you speaking of stainless steel threaded rod?
I have to anchor large air compressors from time to time and I typically use wedge anchors for this application. Do you find the wedge anchor inadequate?
I find the wedge anchors "uncertain". Stainless Steel grades can be chosen for hardness/flexibility, McMasterCarr has a nice breakdown of what is what. My concern with expansion bolts or wedge anchors, is the localized pressure they put on the concrete, and if it starts to slip even a little bit, with a listeroid, it's going to end up somewhere else. I used all-thread because it has lots of surface area to grip with.
So someone else may chime in and say their epoxy anchors let loose, and the wedge held fast. Just a matter of opinion.
makes sense to me, thanks.
I have a basic idea of what I want to do with my 4" concrete garage floor. I hope that you don't mind if I run this by you for your opinion.
I would like to pour a 9.5" slab on top of a rubber horse trailer mat on top of the garage floor,
and then put another rubber horse trailer mat on top of the 9" slab, and finally set the generator (with stand) on it.
I am hoping this will give me the necessary weight and maybe get a little resiliency from the 2 - rubber pads.
The garage floor has a grade to it. Not much but probably enough to make slab and generator travel down the grade. I do not know how to handle this problem since the slab will be isolated from the garage floor with a rubber pad. Should I just tie the garage floor to the slab by drilling half inch holes into the garage floor and sticking rebar into it with about 7" sticking out into the slab?
Thanks a whole lot for the help. I am just an electrician who is finding out that there is a science behind all of this.
Jim
