google "Simpson Strong-Tie concrete epoxy" to find the dealer near you. It's a simple "42" step procedure.
Drill hole with masonry bit (s) in concrete - read the label first to find out what size hole to drill for your size of anchor bolt.
(I did my drilling in 2 steps, small pilot hole, then the final di hole.) Some masonry bits require water, some don't Be sure. You don't want to punch through the concrete - if it's a 4" slab, I'd only go 3.5" and stop. I don't even know if 4" slab is thick enough for a listeroid, or if it has enough re-bar in it to not crack in 90 seconds.
If you hit a piece of re-bar, they have a special masonry bit with notches to chew through it, plain bit's wont cut rebar.
Then you brush and air blast the hole clean
Then you clean the SS all-thread you plan to use - get all the oils off
Clean the holes. Clean the all-thread. get some newspaper (mop up mess) and wax paper (use as non-stick washer under fender washer) place a nut, fender washer, waxpaper washer on the all-thread, and get all of them ready.
get the epoxy ready, the caulk gun it installs with, and be sure you got enough epoxy (chart for hole depth and di, and bolt di) on side of packaging, and I found an on-line calculator for this too. Mine used 2 tubes, and I had a little left over. Without the washer, the bolt wants to settle deeper, and ooze epoxy up into the washer and threads and nut, mess to clean out.
let cure for a couple extra days.
Don't use grade 8 bolts, shock will snap them.
