How does a 6-1 get over heated? There were a few times I did start the engine, during the project, without any water in it, but only ran it for a minute or so and shut it back down. Do you think that could have over heated it? Or is over heating topically done with high RPM at heavy loads? Is it true that you can safely get more hp out of a 6-1 if you adjust the governor
to reach 750 rpm. someone said you could get 8hp out of it. But is this harmful and would it cause the Lister to over heat?
Thanks,
Gordon
Hi Gordon,
Cracked heads on CS engines, that I’ve seen, have been caused by lack of coolant, burst pipes ext. I’ve had a few with the cylinder waterways full of sludge and that ends in a blown gasket due to poor circulation.
You won’t have done any damage by running yours for a couple of minutes.
You don’t give any history to this engine. Have you just had it? How long has the head gasket been on? Ext.
I take it you have the top coolant hose going strait up with no dips? The gasket will blow next to the exhaust port if the thermo syphon is inefficient.
It would be worth you checking the mating surfaces are flat and smooth on the head and cylinder; I’ve had some that look like they’ve been used as an anvil!
As Stan says, you will run into problems if you try increasing the speed too much.
Lister did make an 8hp CS and they run at 850rpm, but that has an aluminium piston, a different governor, smaller flywheels and other mods.
Another consideration is, as you have an SOM, the frequency of the genny will increase with engine speed.
Mark.
