Author Topic: Anyone using Redstone now?  (Read 77640 times)
« on: May 16, 2013, 04:55:07 PM »
Seems there have been no posts re the Redstone for quite a while. I understand there were only about 30 of these imported into North America. Is anyone running one now? I have a friend who bought one, set it up for back-up power, hardly ever used though. Curious about how they have worked out?
Regards,
Stan
Re: Anyone using Redstone now?
« Reply #1 on: May 16, 2013, 10:27:06 PM »
I'm curious too.  Saw one while back in Ottawa but never owned one.
They seemed like quite robust machines.
Stan
Randybee1
« Reply #2 on: July 10, 2013, 01:37:42 PM »
I have one but it's in deep storage until I finish my Cat build and Listeroid 6/1 build
« Reply #3 on: July 13, 2013, 06:05:08 PM »
Randybee.......I know I would be interested to hear about yours when you do get around to setting it up. I helped a friend do a tear-down and reassembly a couple of years back. That one was full of casting sand. We cleaned it out and reassembled checking clearances etc. Ran fine, but has not gotten used since. Doubt it has even 1 hour on it now. Wish I had more to report, and am interested to know others experience.
Randybee1
« Reply #4 on: July 16, 2013, 09:45:17 AM »
Hugh, I hope to finish my Cat build in about 3 weeks time. Hopefully by mid August I will start my Redstone build. I already have it and an ST head bolted to an I-beam frame. I had Randy Almand machine a pulley for me for the engine and the ST. My first order of business will to take it apart, clean and spec it. Hopefully I'll start posting some pics in about a month.
Randy B
« Reply #5 on: December 18, 2014, 09:48:29 PM »
Saw that above mentioned engine in service yesterday.  Not a lot more to report. lHas a total of about 5 hours on it, so can't say much. Drives a ST 10Kw gen head..
It is in a room about 10 X 12 ft. and seems very loud compared to a 6/1 Lister(oid). Mostly intake noise, though what % is hard to say. This Redstone is being used as a standby unit, so will probably not get a lot of use during its life.
There, at least one is working for its living, even if part time.
Randybee1
« Reply #6 on: July 10, 2015, 10:42:47 AM »
Well, My Redstone is still in deep storage. I'm working on finishing up putting together a Chinese Yanmar clone, a 2 cyl Kubota and a 3 cyl Kubota. Maybe next year I'll get to tear in to it.
hawaiian diesel
« Reply #7 on: September 18, 2015, 11:15:33 PM »
I too have a Redstone in Hawaii. It is also sitting deep in the garage. Mounted on an I beam with a 10kw head upgraded by Power Solutions. Randy Almand  custom pulleys geared to 1500 rpm on the Redstone. I don't think you can find Randy's pulleys anymore.
 One day I hope to have it running.
(sigh)
hawaiian diesel
« Reply #8 on: July 28, 2017, 06:19:47 PM »
Update... Still havn't worked on this project. 0 hrs. on engine. Make offer if you're interested in this engine and 10kw Power Solutions gen head. dnpn1 at  outlook dot com
Randybee1
« Reply #9 on: August 02, 2017, 12:14:07 PM »
I still have mine and it's still setting in the garage under a tarp. I finally got motivated on finishing my Cat/Perkins build after something like 4 years or so. It'll probably be a few years before I touch the Redstone. Too many other things in life.
rp48
« Reply #10 on: August 31, 2017, 11:17:16 PM »
I finally got my Redstone up and running. Have had it since 2009. I took it apart, cleaned and checked everything. Put about 2hrs. on it, then stored it. Moved it to my new pole building last week. Made a hardwood skid and mounted it and a 5kw ST head that I also have had since 2003. I plan on getting a 10kw head this winter to hook up to the engine. The engine starts and runs fine.
        Ron
« Reply #11 on: September 01, 2017, 10:03:55 AM »
Looks a lot like a Chine Diesel to me.
I think the redstones refered to here were a bit Different to the one you have!
Either that or I'm missing the joke.
I am going to pick up a similar engine next week. Been looking for one for ages. I have a tiny little 165 engine I love. the thing is rated at 3.5 HP I think it is but will outpull all my 5 and 6 Hp rated engine all day long and without fuss or smoking.  This one is a 5hp so should be a beaut.  I'd really love something on the large side in one of these and water cooled.  15-20 Hp so I could power whatever I wanted.  :0)
maybe I'll get lucky and find one at a sensible price one day.
Probably the day before I cark it or something.
Tom
  • Green power is good.
« Reply #12 on: September 01, 2017, 04:48:45 PM »
They do look like a pretty much standard china diesel with the addition of a second flywheel. Perhaps a specialized version for electrical generation?
Tom
Randybee1
« Reply #13 on: September 05, 2017, 07:13:15 PM »
RP48: When you took it apart was there much dirt/sand etc inside? Also, does it run smooth on that pallet or is there some vibration
rp48
« Reply #14 on: September 05, 2017, 10:04:02 PM »
Randybee1;   There is some vibration, but not severe enough to cause a problem. I run the engine about 1400rpm to achieve 1800 rpm/60hz at the generator. When I put a 4800watt on it, the engine smooths out.
