Went ahead and took the plunge on a Changfa S915M/ST-7.5 generator combo today. Looks like
only 4 left out of 10 on Ebay (Item number: 7627444600). The seller at Motors,Generators &Stuff
name is Mohammed has great feedback and has been clear and prompt in my communications with
him.
I will probably use the 3rd generation serpentine pulleys and coolant plate from George at Utterpower to drive this generator set. Will also be using a six-circuit Reliance transfer switch (#R30216B) from ReadyPower.Com.
I need to decide what auto radiator to tie into this setup for cooling. One of the mechanics at
work offered to give me a Subaru radiator, which I know is a cross-flow, but he thinks it can be
modified by sweating on a elbow at the fillneck and stand the radiator fintubes vertically. By adding
a elbow at the fillneck and extending it vertically with a standpipe and add a coolant overflow to
capture any overpour and keep out the air.
For a free radiator it might work, otherwise I will look for a suitable downflow.
Will also be constucting a generator cart from 3x3" angle, double 2x6" wood sideframes, 2"x6"diameter
1200# caster wheels and small crank type trailer jacks to offload wheels on the generator slab inside
a wooden noise suppressed shed. This way if the unit needs servicing it can be rolled out of shed
under an A-frame hoist if the need arises. Will post picks when all it done.
Great info and participation on this site!
Thanks in advance for any radiator recommendations you care to make for this project as well.
G'day
OilCan
