Author Topic: Homemade Electric Start  (Read 9447 times)
gary_o
« on: January 01, 2013, 07:38:37 PM »
I just couldnt help myself here as i had a a starter generator from an old golf cart,pictures are posted in the gallery.
Cant quite figure out how to attach an image in a post.
Gary
Quinnf
Re: Homemade Electric Start
« Reply #1 on: January 01, 2013, 09:12:06 PM »
Gary,
The rule around here is, "Pictures or it never happened."  Sign up for a web-based picture hosting service.  Photobucket.com is a popular one.  Once you upload your pics there you can link the image to that using the little picture thingy icon.
Someone might have more concise instructions on how to post pics.
Quinn
gary_o
« Reply #2 on: January 01, 2013, 11:19:54 PM »
gary_o
« Reply #3 on: January 01, 2013, 11:22:50 PM »
« Reply #4 on: January 01, 2013, 11:24:04 PM »
Welcome to the forum!
Paste a link (URL) to your pictures here... The forum software does not allow a direct paste of the actual images themselves.
« Reply #6 on: January 01, 2013, 11:25:55 PM »
Good going!
That is a unique starter configuration for an AC
« Reply #7 on: January 02, 2013, 07:34:08 PM »
Nice job !
Does the starter continue rotating after the engine has started ?
Could wear out the shaft bushings.
Unless you are also using it as a DC generator ?
- Kubota Z482 - 4kw
gary_o
« Reply #8 on: January 03, 2013, 11:57:05 PM »
It is hinged with a spring so when tension is released(IE started) the belt is loose enough it doesnt rotate much.
just temporary as i am looking for a correct starter(and funds)
Gary
listard-jp2
« Reply #9 on: January 07, 2013, 03:27:09 PM »
Not only will you need the starter motor, but also the unique bracket that goes between the engine and starter motor.
buickanddeere
« Reply #10 on: January 09, 2013, 01:43:24 AM »
  The starter generator rotates at all times. Starts the engine and charges the battery. Normal operating rpm with the engine at fast idle is 10,000rpm when use don Kohler k181 engines.
  I've seen them rated up to 25amps charging capacity.
