Turning back to the original post about two ST heads on the same bus, driven from two Listeroids: That was a 'pet' project of mine a few years back. I spent considerable time working through the design. In the end, I concluded that for me, there was too much technical risk. The main concern I had was the circulating, or synchronizing current that flows between the two ST heads. Ideally it is close to zero. But in the real world, this current flows when the two ST heads are not in perfect sync. And they are always falling out of perfect sync (maybe by only a few degrees, but nonetheless significant) as the Listeroid speed varies throughout its 4-stroke cycle. It runs a tad fast at the start of the power stroke, and slows down through exhaust, intake, and most dramatically, during compression.
I wasn't able to convince myself that this synchronizing current was under control, and could be maintained at a low value.
This is a problem at its worst with single-cylinder prime movers - made worse in the case of a Diesel because of its high compression ration, and made still worse by the low speed of the engine, and the large ratio of the belt-drive. I concluded parallel operation was a tough nut to crack and went ahead with a single, larger engine.
So, I'd like to hear from anybody that has put two listeroid-driven generators in parallel.
