Author Topic: Witte Diesel question. 14 hp veritcal?  (Read 4958 times)
RJ
« on: November 30, 2012, 09:19:39 PM »
Did Witte ever make a 14hp vertical diesel? Found a fellow that claims he as one, says it has external valve push rods and solid flywheel. I don't know anymore more about it at this time. I'm having a hard time finding info on the history of the production of witte diesels.
Re: Witte Diesel question. 14 hp veritcal?
« Reply #1 on: November 30, 2012, 10:04:11 PM »
Hi RJ,
I knew they made a couple of verticals but none this large.  You mentioned the solid flywheel(s?) and exposed push rods which pushes it back sorta pre war (guess).  I rely on David Johnson at wittemania@cox.net for technical stuff.
Casey
RJ
« Reply #2 on: November 30, 2012, 11:57:53 PM »
I stand corrected I spoke with him today, it's a horizontal with exposed rods. Which seems to make more sense.
Are these good engines? I don't know anything about them. I was looking for a lister CS when I came across this.
« Reply #3 on: December 01, 2012, 04:05:14 PM »
It's still pretty old - uppy-downy or lefty-righty.
These are great engines designed to work year after year in the oil fields - even the earlier exposed push rods.  But if you can't get the part to repair the machine it's a very much over-sized paper weight.
My engine is rated at almost 8 horse power and the one I still dream of is 12.  These are the two models I've actually touched.  There are others and a few have been discussed here on listerengine and microcogen.
Notice where mine was manufactured?  Just click your heels together.
http://listerenginegallery.com/main.php?g2_itemId=7451
Casey
« Last Edit: December 01, 2012, 04:08:01 PM by LowGear »
bschwartz
« Reply #4 on: December 01, 2012, 09:57:20 PM »
Uh.... I didn't think Dorothy clicked her heels together to get back to Missouri...   ::) ::)
-Brett
RJ
« Reply #5 on: December 03, 2012, 10:41:16 PM »
This is a 12hp engine that I was looking at. He wanted 1800 for it. Said it ran fine.
« Reply #6 on: December 04, 2012, 10:40:49 AM »
Hi,
1.  Literacy is it's own punishment.
B.  There are a couple of them on youtube.  David Johnson does have a few parts for these engines.  Like my 8 HP version, many have emergency oil and water temperature shut down and pressurized oil with "sluff" filter.  I think the 12 HP units weigh in at 1500 pounds and run at about 750 RPM.
Good luck.
Casey
