Hi Bottleveg,
I am now getting complete contradicting advice here.
You say I could exchange my 6/1 SOM flywheels onto the 10/1, and just received from the SmokStak forum:
quote:
The single cylinder flywheels are designed to balance the single cylinder engine and the twin flywheels are designed to balance a twin and they are therefore completely incompatible for obvious reasons if you look at the balance masses in relation to the key irrespective of the more minor issues of size,shape weight etc. They must not be swapped.
Very succinctly stated. That was probably from Peter, the forum Admin over at Smokstak. I suspect Peter has probably forgotten more about these engines over the years than most of us will ever have the opportunity to learn. You can take what he told you to the bank and sleep soundly.
The question isn't so much "can you" as it is "should you." Flywheels for twins don't have counterweights. Any flywheel from a single will have a counterweight (spoked flywheel) or a lightening hole 10/1 or SOM, or unequal trapezoid shaped cutouts (8/1) in the web. Those features offset the center of mass from the axis of rotation, and are used to counteract the reciprocating forces within the engine. If you hang one of those flywheels on each end of the crankshaft of a a twin, which is already balanced by virtue of the 180 degree crank angle, the flywheels will exert a lot of force on the crankshaft and impart a rocking motion along the axis of the crankshaft. It might not cause any problem other than some vibration, or it might end up snapping the crankshaft after a while. In the case of a 6/1 flywheel the counterweight weighs 3 lbs, and the centripetal force generated by the weight spinning at 650 rpms is 120 Gs, or 360 lbs. on each end of the crankshaft. That's 720 lbs of force spinning around doing nothing but bending each end of the crankshaft. Metal fatigue is cumulative.
Bob, correct me if I misunderstood what you said about that engine. Did you say the crankshaft on that 10/2 snapped after the SOM flywheels were fitted, or was that before?
Quinn
