I use one of those drills at work Bob. Adjust the head on its base for maximum ridgidity...you will see what I mean.
I am getting my head around a cart for the CY. I have a matching set of heavy wagon wheels, 30 and 36 inch dia. Stub (well not so stub) schedule 80 axles welded into a channel and threaded on the end for a cap to hold the wheels on. Tapered bores in the hubs so I will make tapered bushings and weld them onto the pipe. Dado the underside of the timber to accept the channel and to disguise it and bolt the channel through the timber in 2 or 3 spots.
Plan on making my own fuel tank from a big pipe with the end caps being flame cut plate and welded on. I can get fancy with that because thats our work, CNC flame cutting. Maybe I will make them tall to gravity feed and just weld a tiny angle iron foot onto it to bolt onto the timber.
At least thats TODAYS idea... Maybe I'll make a steel frame
Good luck on your cart or skid. I 'aint doing anything yet 'cause you'll change my mind when I see yours. You putting the air tank on and going with the Carter rad ? The HR engines were tank cooled except in the elevators as per my email...did you get it ?
Sorry to hijack...wanted to stay on topic
