Parts availability might be an issue though... depends somewhat on your location.
Your not wrong there, as genuine parts are eye wateringly expensive, though like Lister engines. Pattern parts are freely available from the usual Indian sources.
FYI: The bottom end design of these engines is remarkably similar to some of the Indian Listeriod engines, with taper roller main bearings and splash lubrication via a dipper on the connecting rod.
