Author Topic: 10 HP Petter mounting  (Read 3594 times)
kingmanbob
« on: June 04, 2006, 08:15:45 PM »
I read alot about the lister hop, and that they need to be mounted on a slab of concrete with no shockmounts. I was wondering if the same is true with the higher revving Petter. If so, maybe I can use very stiff mounts rather than the usual soft mounts to at least stop the soundboarding.
« Last Edit: June 05, 2006, 01:57:50 AM by kingmanbob »
listeroidsusa
Re: 10 HP Petter mounting
« Reply #1 on: June 05, 2006, 02:34:06 AM »
I can't speak for all of the petter type engines but the ones I had built by LG were smooth runners and the governors worked well. Sid on this forum bought the last few that I had. He can tell you more about the running characteristics of the petter type engines from his experience.
Mike
sid
« Reply #2 on: June 05, 2006, 02:51:48 AM »
mike is correct/ both will run all day on 4 wheel cart and never move or shake///smoother than an antique engine that I own//sid
8 hp stover 1923
8 hp lg lister
1932 c.s bell hammer mill
4 hp witte 1917
5 hp des jardin 1926
3 hp mini petters
2hp hercules 1924
1 1/2 briggs.etc
kingmanbob
« Reply #3 on: June 05, 2006, 03:32:18 AM »
Thank you for your replys. I think I will use my favorite Stable-Flex mounts.
