Author Topic: crankshaft run out  (Read 2530 times)
20/2
crankshaft run out
« on: February 12, 2012, 07:37:19 PM »
Many thanks for all you responces to my oil problem.
if you all could help me a little bit more, this is to do with crankshaft run out or better known as bent chankshaft.
if i put a dial gauge on the crankshaft it run out at 40 thou, i have stripped the engine and strieghtend the crank to within 5 thou,
is this normal for this type of engine ?. also i would like to hear from any one in the uk with a twin cylinder cs . thanks
