Hi All,
So, I finally decided I needed to have a closer look at the 20kW alternator that I was shipped, and actually spin it up and make some voltage. Of course with the Lister still buried away, I thought I better find something else to spin it up with. With no 48mm shaft pulleys anywhere in sight, I got out the dril and drilled a small hole in the end of the shaft. Then to the tap & die set, and threaded the hole. Insert a bolt, put the appropriate attachment on the drill, and voila! a drill powered generator.
Just in case you were wondering, a 4 Amp drill can spin up a 20kW head, but you might want to use a drill that's still in warranty as you'll surely finish off the brushes. So I spun the unit up, and it showed voltage, and the control panel light came on, just before the drill died. So, with it being nice outside, I decided I could poke around on the generator for a bit before getting back to real work. Well that proved benifical, because sun was a little better than the previous light that I looked at the generator with, and the prints the chinese sent me make a little more sense.
----MAIN FIELD*====<===<=*X-FIELD*----- (Generator shaft)
MAIN STATOR X-STATOR
[A V R] =====>=====>----->
So, I've got my head wrapped around this unit now, so I thought I'd explain those interested how it works. Keep in mind that this unit is completely brushless. So closest to the shaft end of the unit is the main field and stator, quite similar to that of an ST generator. However, instead of the field recieving voltage from brushes, it is powered from another small generator at the other end of the shaft.
1) The AVR provides voltage to the stator of the exciter (X-STATOR)
2) Voltage is induced in the field of the exciter (X-FIELD)
3) X-Field voltage is rectified through a set of diodes
4) X-Field voltage supplies the MAIN FIELD with power through two wires running along the shaft
5) Voltage is induced in the MAIN STATOR, and is used to power loads, as well as the AVR
So all in all, I think it's a neat setup, and it should work out pretty good....
Thoughts, opinions, comments, questions???
