the JK6 engine has some features in common with the JP range. But is otherwise a unique design as it was developed as a true marine engine from the start, meaning it can all be stripped down from above leaving only the lower crankcase / sump insitu.
I seem to remember that all of the JP/JS/JK series are like that, the JK6 is not radically different to the others in the series, the main differences between the three models were rocker gear lubrication and the compression change-over deleted on the JK.
The JP was around as a marine engine long before the JK. I have a marine engine book where the JPM and JKM share common crankcases etc etc.
The early parts books for the JP and the latest for the JP/JK/JS use essentially the same pictures of the crankcase.
I'll be happy to be corrected, but I believe that to be the case. I have a JK4 generator sitting up at the farm. I'll try and dig up a 6-cylinder book.
Peter
EDIT: The 616/JP6 does have a split crankcase, before the JK came along, but it is a different arrangement to the 1,2,3 and 4 cylinders. So I am corrected on that one by the 616MGR parts book.
