Sorry for the delayed reply. I've been away since I posted my question. I tried to reply a couple of times and got half way through each time when the dodgy motel internet connection vanished - so I gave up.
Hi Wlb,
I've an HR2 Lister charging via an SW4548e, have you tried going into the 'gen menu' and altering the frequency/voltage parameters? The only bother I ever had with mine was when the AVR on the genny started acting up and it would not synch. Just go into the meter items for voltage and see what's happening as it tries to synch, mine was all over the place and kept failing to synch or dropping out after a few minutes. The other thing you could try is adding a load of 1 or 2Kw onto the genny before whilst it's flashing red and see if that helps it to synch. If it does it could mean your AVR is on the way out or perhaps a governor problem.
I'm no expert by the way so perhaps someone who actually knows what they're talking about will be along shortly
Cheers, Paul
Thanks Paul,
Mine is a 230v model too. I presume that AVR is automatic voltage regulator? I could be wrong but I suspect that it doesn't have one and that all regulation is speed related and controlled by the governor alone. The only "electronics" are the Start-O-Matic box and what looks like the starting battery's charging transformer and rectifier, plus the starter relay.
I did try a 1500w heat-gun as a load but it made no difference, which did surprise me.
I've been into the Generator Menu and played with the voltage and current settings, widening them or reducing them where applicable.
The old DR2424e has a DC current limiter for battery charging but it has always been set to maximum (just a trim pot) and the charger just takes what the generator can deliver - about 50A into a 24v 630AH battery bank during the Bulk stage. The Lister just loads up and holds steady.
The SW3024e on the other hand limits DC current by limiting AC In current. My initial sync problem was immediate until I realized that I'd forgotten to divide the AC In current setting by 2 to allow for it being a 230v model, not 110v. Once I did that it synced OK at first but lost it later after about 10 minutes.
I tried it again today but this time there was a water transfer pump running and it held sync for the whole charging period. But I suspect that it went into Absorption mode very early as it had been a sunny day.
Warwick
Which generator head and controls do you have on your SL2? That little engine may not have a high degree of speed stability and if the inverter is trying to synch to it, could be related. Does your Xantrex strictly require a power synchronization in order to charge the battery bank?
Thanks dieselgman,
The engine holds quite steady voltage when charging hard through the old inverter/charger.
The alternator is a direct-coupled 1500RPM Lister 4kVA unit with serial no. 29543/35.
I've tried running a 5.6kVA unit driven by a 13HP Honda petrol engine, but it didn't sync properly with that either.
I've got another Honda but can't try that as its capacitors are blown and it's still in bits. It was running on a very hot day and didn't like it much.
I've also got an 800RPM 8/1 with a belt-driven alternator. It's skid mounted but not hooked up yet. (In storage). That's the engine that I ultimately intend to use and keep the SL2 as the back-up.
Syncing is completely unnecessary for the battery charging. It's there because the inverter is designed for grid connection too and syncs with the grid before switching over. When it detects incoming AC from the grid or a generator, it waits to make sure it is steady, synchonizes to it, then switches to battery charging and replaces the inverter output to the house with generator feed-through power. This allows the batteries to be charged, unloaded.
When not being used to feed AC back into the grid, syncing is unnecessary. All that happens is a blip of a few milliseconds in the house supply as it changes over. The only things that really notice it are compact fluorescent lamps which blink slightly, once. This is how the old DR2424 operates.
Warwick
