Author Topic: Looking for .040 oversize piston  (Read 8927 times)
rleonard
  • Mattoon, Illinois
« on: April 22, 2011, 04:49:32 PM »
I have been stalled on my VA project because I thought the engine was mechanically louder than it should be.  I finally pulled the piston and discovered way too much piston to cylinder clearance.  It will take a .040 oversize to get things back to size.  Central Marine only had stock size.  This is a VA so it has an air cooled cylinder.  Sleeving could be a possibility if all else fails.
Any one have a .040 o/s piston and ring set on the shelf?
Re: Looking for .040 oversize piston
« Reply #1 on: April 23, 2011, 03:41:30 AM »
I will be checking on old stocks for you Bob, also on availability of replacement cylinder to bring your engine back standard.
rleonard
  • Mattoon, Illinois
« Reply #2 on: April 23, 2011, 09:45:43 AM »
Thanks.  I know that I can find a solution.  Might be re-sleving, or a fresh piston.  One way or another.....   Patience.
listard-jp2
« Reply #3 on: April 23, 2011, 11:50:49 AM »
If you find that you are struggling to find a +0.040" piston, then send me a PM, as I have a contact in the UK who has some. They are Indian in origin, but are good quality, as I have used some of these pistons myself in a Lister CS16-2 with no issues to date.
« Reply #4 on: April 23, 2011, 01:23:25 PM »
Or, better yet, a standard size replacement cylinder. Standard pistons and rings are relatively easy to supply!
rleonard
  • Mattoon, Illinois
« Reply #5 on: April 24, 2011, 01:33:36 AM »
I would think that VA cylinders are even more scarce than CS oversize pistons.  I did find one, .050 oversize, which is OK.  Also Devang Rathod of - dev_precision_engineers in India can get them for me.  I am working on putting together an order with James Helmuth for him to restock so we can save on shipping.
« Reply #6 on: April 24, 2011, 03:14:41 AM »
Yes, there are literally hundreds of suppliers in India who will offer this product... the pistons are not of concern except for quality of metallurgy and manufacture. If you have a supplier for the cylinder castings, we would also have an interest in stocking some of these. We bring a container over from India every 3 months. It would be easy and relatively inexpensive to accomodate the VA components.
dieselgman -  gsj@gci.net
