Krazion---
I live way off grid on generator power only, except a small inverter on batteries for middle of the night internet access if needed.
My shop is a one man, mostly three phase, machine shop with a 220 amp TIG welder (usually run at 120 or less), 5HP bandsaw, 5HP lathe, 3HP mill, 2HP surface grinder and all the lights, hand tools and drill press, sharpeners, etc needed to make or repair what interest me. I run the entire shop, including 400 watts of florescent shop lights on an Onan 15Kw water cooled diesel. I run the welder fan and a couple 1500 watt electric space heaters (outside in summer) to load the generator some. Otherwise it carbons up and gets smoky in a hundred hours or so. On days I don't need the bandsaw and do need water I run it's power source (everything on waterproof industrial plugs) to the 3HP well pump which draws enough to keep the Onan running clean.
Unless you're an "in the shop and working eight hours straight" guy, running a shop by genset is a true pain in the rear. I hate the roar of the Onan but it's nice to have compressed air all the time or be able to run a grinder/wire wheel 'just for a minute'.
My Lister runs all the main building's needs about 15 hours a day. I have it wired 220 that's then split into two circuits with four wall plugs each. The freezer and 400 watts of lights and the building heat pumps in winter takes one circuit and the computer room (300 watts) and 800 watts of lights and wall wart battery chargers take up the other.
You can run what you have now on 14 to 15 Kw, but that means that great doodad for $19 at the auction but is three phase means a new generator before it's useable.....and it WILL be!
Think of generators just like machine tools. You can do small jobs with big machines, but you can't do the big jobs with a small one.
I'm in the process of re-designing a house and shop. I'll use at least two generators. One large and one small. There will also be a spare and a 4Kw portable gas just to pre-heat engines in the winter, too.
If you're off the grid your power needs change a LOT. Think hard on it before committing to one plan.
My story is posted at
http://www.utterpower.com/jack_belk.htm
