Thanks for the replys, the fuel pump, return lines,etc are all enclosed with access to the crankcase, so I first thought cracked return line or leaking fuel line somewhere. However once I took the engine apart I found a nickel size hole on the top of one piston and a pea size hole in the other one.So that would explain how the fuel is getting in. Now what causes the holes? Bad injector nozzles? acting like a torch? Injectors out of time? engine out of time? Surprisingly the cylinder walls are good, but both top rings were shot. AS are the valves and heads. And this engine crank started very easy.Go figure.
